jcshores
New Member
Hi all,
I posted this on MOTORBOATS and was told that this may be a better place to find an answer.
I have a Suzuki DF4, 4 stroke, 4 horse on a 14 ft aluminum Crestliner, in the waters of SW Florida. The engine MIGHT have 20 - 30 hours on it. In early June I had surgery and have been laid up since. During which time I had the engine inside my garage. I did not drain the fuel or "winterize" it which has proved to be a mistake. A couple of weeks ago I got it out to knock the cobwebs off so I could get at least SOME fishing in before Fall, and here is what it is doing; It will crank (choked)fairly easy. And as it warms up I slowly push the choke in. Once it is fully warm, it will only run with about half choke and then sluggish. It will not idle with the choke all the way in or out. It is burning fresh fuel (Idrained it). I have sprayed into the carb some Carb and Choke Cleaner (SP-3C) I have for my motorcycle, it does nothing to help. Is something sticking? Did leaving it sit for 2 months gum up the float? Do I need to take the carb apart to clean it and if so, is there a DIY doc on the web I can reference?
Thanks in advance.
BTW, turns out the fishing has been bad lately anyway what with all the hurricanes! crud...LOL
Thanks in advance.
