I want to remodel the interior and rebuild furniture but don't know where to find suppliers. Any suggestions? I am in Shepperton, South of England. Thanks.
@Lucas Gan did you sort out your fuel tank? If you're going to strip the boat interior out, now would be an ideal time to get that tank out and replace it whilst the interior is in bits.
@Scala , I didn't sort it yet. I don't want to strip all the interior structure. I just planning to replace the interior top layer such as liner, carpet, wallpaper, and upholstery, etc. I am trying not to strip the structure as that could be expensive to rebuild. The leaking starboard 200-gallon fuel tank is empty. My plan is to cut a big hold on top of it from the closet floor. So that can make a 50cm x 90cm hole on top of it to gain access, then I am going to remove all the baffles and fit three to four small tanks inside it to recover 70% of its capacity hopefully. The only trouble to do is the connection between the small tanks and how to secure the small tanks to avoid movement. I should start this tank project soon.
