WayneS
Today we handed over the deposit on a new Beta 20Hp engine to replace the ever failing piece of junk that pretends to work (20year old Faryman 12Hp).
This has raised a few questions and I wonder if you folks could comment:
Engine Bearers.
We will not be able to use the existing setup which is a GRP plate that the current engine sits on. I intend to remove all of this plate and glass in two hardwood bearers directly onto the hull (GRP). Then use 8 coach-bolts to secure the mounts down onto the bearers. Am I on the right track. Alignment is not a problem for me as we are maintaining our Hydraulic drive system.
Fuel Return
Currently I only have a single pipe from the tank. The new Engine has a return way. Do I need to take this return back to the tank or can it simply T into the feed pipe before the pump?
Raw water pipe.
I was speaking to a guy a few weeks ago who suggested that we use fuel hose for the raw water feed. He has done this so that in the event of a fire, the engine should still get cooling water. Any comment?
Prop.
We currently have a 2-blade folder. We are thinking of just fitting a std 3 blade. Does it make a huge difference under sail. Are we talking knots or fractions of knots.
I’m sure that there will be loads more Q’s as we progress but that’s a start.
Regards
Wayne
Engine Bearers.
Fuel Return
Raw water pipe.
Prop.
Regards
Wayne
