doug748
Well new to me anyway, I don't think this has been posted before, the Temo from France:
If you drop it in the oggin it floats.
That is because the cheap ones are made for the mass market mainly in the USA where they are primarily used as trolling motors for fishing on lakes and rivers. They are really not comparable for the typical usage here with a Torqeedo or epropulsion which are specifically designed for use on tenders, dinghies and small sailboats.Cannot believe the price of the Temo and Kicker at about £1300 - 1400! Freshwater examples seem to be disproportionately cheaper unless to inhibit corrosion from salt water makes a major difference in design and materials. The Kicker looks so much more advanced and substantial in design etc compared to the Temo at the same price. A power drill and long shaft with a prop on the end comes to mind.
The Kicker's battery is 1/4 the size of a Torquedo or E Propulsion, which are broadly similar. They have much more power as well as more endurance. I think you might find all of the cheaper ones to be barely adequate in a marina. A tidal anchorage would be very challenging indeed.A friend has one for her inflatable. Watching her use it I would say that it is better used on a rigid tender in the sculling oar notch. It’s quite long and it would be ideal standing with it in the transom notch.
I think a better competitor in that particular market is the Kicker Kicker
I‘ve had a Torqeedo for many years and it is very good. If I were to start again I’d probably go for the ePropulsion. The kicker looks as if it would do a lot of the things I’d need it for. For now I’ll stick with the Torqeedo since I have a couple of batteries and a solar panel.The Kicker's battery is 1/4 the size of a Torquedo or E Propulsion, which are broadly similar. They have much more power as well as more endurance. I think you might find all of the cheaper ones to be barely adequate in a marina. A tidal anchorage would be very challenging indeed.
Yes you get what you pay for.That is because the cheap ones are made for the mass market mainly in the USA where they are primarily used as trolling motors for fishing on lakes and rivers. They are really not comparable for the typical usage here with a Torqeedo or epropulsion which are specifically designed for use on tenders, dinghies and small sailboats.
