Idlewild
New Member
I own and am living aboard a 1983 Carver Mariner 33. How I came to be here is a long and probably not very interesting story, let's just say that life's circumstances landed me here, where I never expected to be, but I am here now and expect to be here for sometime. I have never previously owned a boat and know next to nothing about them, hence the preceding introduction. But now that I am here I find that it is a good fit and I plan to make this a "permanent" lifestyle, and I am already looking to find a somewhat larger boat, in better condition than this one.
I bought the boat about four months ago (October, 2014) and since moving onboard have found a lot of problems that the seller assured me did not exist (electrical problems, heaters that don't work, no macerator, shore power lines have burned out TWICE, numerous leaks when it rains, etc, etc, etc) Ok, it is my fault, I bought the boat sight unseen while I was in Florida and took possession of it in New Jersey, and I expected due to the age of the boat that there would be some things that would need to be fixed. What I did not expect is that the seller would, after I had paid for it and before I could get to New Jersey to take possession, take the splitter so I had no way to hook up the power without immediately buying a new splitter, and that among other things he took off the boat after I had paid for it was a heater to warm the water lines to keep them from freezing up. I just discovered this a week ago when the hot water stopped running. Now is not the ideal time to find out as it is 22 degrees out and the cockpit access panels are covered with three inches of ice and snow.
So I am hoping someone might be able to tell me what they think the problem might be so when it warms up a little I can get to the hot water heater and lines and fix it.
1.) The pump works. I can hear it running and water comes out of the cold side of the faucet.
2.) The water heater worked and probably still does but I have turned it off until I can fix the problem.
3.) When I got up a couple of mornings ago (after a very cold night) and turned the pump on, the water comes out of the cold side of the faucet, but only a small trickle out of the hot side, and then it stopped completely.
What I don't understand because I have not seen the pump of how the water lines are configured, is why the water would come out of the cold tap but not the hot. The tank is full and is filled on Tuesday's and Friday's.
Although it would be nice to have hot water I am not too anxious to get down in there in 20 degree weather and three inches of ice on the poop deck.
Now I have read some threads and know I will probably get hammered so bring it on and I will suck it up
, but if someone knows what the problem is I would appreciate that too!
Thanks!
Thanks!
