New Boat at Last
Gludy
19 Aug 2001
Brecon, Wales
www.sailingvideos4us.com
I now own the Fairline 59 at Port Solent - its the second boat I have purchased from the same pontoon in the last 2 years!
It has had to come out of the water for a number of jobs and so my first trip was a few hundred yards to the lift - all went OK and I put her into the sling OK and without touching anything. After this little first task was complete I was asked why I had not used the bow thruster and the answer was simple - I forgot it was there!
Watching her being hosed down I chatted to the lift driver and he informed me that lots of folks bashed their boats coming into the lift but if you knew what you were doing, you did not need to and that there was, without doubt, no need for a stern thruster. I queried this a bit more and he added, well all you need is the two shaft drive engines .... but mind you, when the wind catches you there is nothing you can do anyway! " That in once phrase made my case for stern and bow thruster!
The logic seems to be this:-
Boating He-Man - can do without bow or stern thrusters just needs his engines but is happy at time when the wind catches him to hit something or maybe do his props in.
Boating Man - he only needs a bow thruster and again is happy for the wind to catch his boat costing many hundreds of thousands and do with it what it wishes.
Boating Coward - he likes both a bow and stern thruster and wants to keep his boat out of danger when the wind catches it. He wants to direct his boat into the berth with a hand held remote control which allows him to stand anywhere so he can see how much gap he has got instead of relying on others to shout garbled versions of the gap size etc.
He wants to be able to jostle batter with 20 other boats waiting for a lock without being forced into shallows and prop damage. He wants to stress his little crew less and lead a more peaceful matrimonial life!
I hang my head in shame ...... I am a boating coward!
<hr width=100% size=1>Paul
DepSol
6 Oct 2001
Guernsey
There is a fine line between wisdom and cowardess.
Congratulations, when do you take her home.
<hr width=100% size=1>Dom
2003 is going to be a good year for me
Gludy
19 Aug 2001
Brecon, Wales
Taking her home on 11th April with an easy trip back via Falmouth and Padstow.
I have has the large screen daylight colour Ratheon system put in the upper and lower helm which has meant that I had to replace a perfectly good function radar system (now for sale along with an 8 man Avon liferaft).
I am having the bow thruster upgraded and a stern thruster fitted - turned out mor expensive than I originally thought because the stern thruster is a waterproof electric motor inside the bathing platform. I have a remote control for the thrusters so I can stand anywhere with a full view of bow and stern to slide her in.
I did not enjoy throwing away a lot of new spare that the owner had let saltwater get to - all rotten in their packaging.
jfm
Jersey/Antibes
Re: new boat. yazzi
Yazzi (most recently) is a 55 afaik. Praps yazzi's owners had a 59 a while back, but I doubt Gludy's 59 is Yazzi now
Gludy
19 Aug 2001
Brecon, Wales
Re: new boat.
tcm - my boat has had one local trip out of the Marina in the last 3 years!!! Hence the reason I had a full engine/equipment survey.
Wh0 is Yazzi?????
hlb
RIP
Any Pub Lancashire or Wales
On the other hand. Was it Mark Tuckwells boat that nearly sunk because of badly fitted thruster. Now I can see the need for a bow thruster at 59 feet. But if you can put the front where you want with the bow thruster and with your two props, you can put your arse end any place. Maybe a stern thruster is necesary with one prop, but with two?? what you going to do with it. You have all ready found out that you are ok with none. Anyway whats up with a fender or three.
Haydn
tcm
11 Jan 2002
Caribbean at the moment
Re: new boat.
wow. So, you saw it the last time you were there!
Yazzi is just a boat that i believe frequents port solent. I had thought it was a 59, but jfm says it is a 55. His wifey is calld yasmin i fink. I say "fink" cos he lives like sort basically where we are in the like rough end of sarf Landan.
jfm
Jersey/Antibes
Re: Yazzi 58 or 59
Do you mean 58? Was there a 59 in 2000? - I think it was discontinued by then, and the new 58 was just out or about to be launched. The last time I saw Yazzi (the Sq55) it was in W Cowes, bout 2 years ago. Had green canvas work I recall.
Gludy
19 Aug 2001
Brecon, Wales
Just taking one example;-
Windy day jostling with a dozen other boats outside Tawe lock - I can find myself in a postion where i need to turn but without revolving around my centre so as the bow swings one way the stern swings another.
In the Marina, in windy conditions it is very nice to be able to go sideways.
In the lock I can simply stand with the remoute and do not need anyone to rely gaps to me - I can see it all and control it in.
I have learnt to do all this without any thrusters but will find it less hassle, less strain with thrusters- it also helps my crew who are limited in number, sometimes to just one on a 60 footer. Anything that makes it easier to handle has to be welcomed.
petem
Cotswolds / Altea
www.fairlineownersclub.com
Re: Yazzi 58 or 59
Right, final answer.
Yazzi I Sq 59 (pre 2000)
Yazzi II Sq 62 (post 2000)
Google for Yazzi Fairline and they're both there.
<hr width=100% size=1><A target="_blank" HREF=http://www.FairlineOwnersClub.com>Fairline Owner's Club</A>
D
Deleted User YDKXO
Agree with you, Haydn. Can't see the point of a stern thruster if you've got 2 engines. Boat will pivot roughly about the same point whether you use the engines or the stern thruster. I think a stern thruster would be worth having on a big single engined boat though
tcm
11 Jan 2002
Re: sternthrusters
a 75 foot boat had these fitted, cost him 12 grand. I don't think he's ever used them. I remain convinced that handling a 30-40 foot boat is miles harder than a 60-80 foot boat.
DepSol
6 Oct 2001
Guernsey
I think you will find its called a luxury. Most boats have lots of accessories that aren’t necessarily required but that’s what the owner wants so that’s what the owner gets.
Also why struggle if you don’t have to? If you can have this extra kit and its no problem financially then hey who’s to say otherwise. I think it looks quite flash manouvering your boat by remote control from the side especially if you are short of people to help with ropes etc then you can at least have some degree of control whilst getting other items ready.
Extra control, cant be a bad thing in my book, pity the frog who half demolished my last boat whilst coming off his mooring didn’t have some extra bit of kit, then I might not have spent the winter out of the water and out of pocket.
