New Battery
Athene V30
20 Sep 2001
Playa del Ingles, Gran Canaria in Winter, the boat
Need a new domestic battery rather than engine start. Looking at battery megastore - what does cold cranking 1000 mean?
Part Number: XV31
Manufacture: Exrider
Volt: 12V
AH: 115
Cold Cranking: 1000
Warranty: 3 Years
Length (mm): 330
Width (mm): 172
Total Height (mm): 242
Weight (kg): N/A
Layout: N/A
Hold Down: N/A
Terminal: DT
Battery Type: Sealed Calcium
Application: Deep Cycle
£79.95 inc VAT
Part Number: XV31
Volt: 12V
AH: 115
Cold Cranking: 1000
Warranty: 3 Years
Length (mm): 330
Width (mm): 172
Weight (kg): N/A
Layout: N/A
Hold Down: N/A
Terminal: DT
£79.95 inc VAT
I have 4 of them
1 x engine
3 x domestic
now entering their 3rd season with no probs
Cranking amps are the numbers of amperes a lead-acid battery at 32 degrees F (0 degrees C) can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12 volt battery).
In other words, Cold Cranking amps ( 1000 ) determine how much power you have to start your boat engine.
Not an ideal choice for a house battery that is required to give considerably less amps over a long period. Batteries are built for different jobs so its worth getting the right battery even if it costs more. Also consider one with removable lids so you can top up the distilled water in it.
In my innocence I assumed that Karouise's battery being described as deep cycle meant that it was suitable for house duties and the cold cranking info was just additional information. I'm afraid I'm one of those who just get the cheapest "heavy duty" batteries I can find and hope for the best. Mine seem to last over six years.
Part Number: XV31
Volt: 12V
AH: 115
Cold Cranking: 1000
Warranty: 3 Years
Length (mm): 330
Width (mm): 172
Weight (kg): N/A
Layout: N/A
Hold Down: N/A
Terminal: DT
£79.95 inc VAT
That'll do you fine for the engine, the electrics, or both.
Ignore the line that says "deep cycle" it be bollox.
