ChasB
I've got a 1982 Carver with two petrol Volvo Penta BB225A engines.
I've been having starting problems, and am going to upgrade the batteries and wiring. I'd like to ask here if what I plan will work ok.
There are two alternators - one on each engine. The manual I have is for Volvo Penta AQ225D and states that the alternator output is 490 W (38A) Searching on-line I find the replacement part is Sierra 18-5959 and is rated at 14V/50 AMP. The original alternator is still on the port engine, and a new Sierra was fitted 2 years ago on the starboard.
The boat is not wired as one usually sees on boats. There are two batteries that can be switched A, B, A+B. Whichever is switched on will provide both house power and engine power to both engines. It's not an ideal arrangement, but rewiring it would not be easy.
The battery compartment has two 100Ah lead acid batteries which both need replacing. The compartment is limited in size and will not take more than two of the same type. However it seems to me that if I buy four 80Ah batteries (which are shorter) they should fit if put in sideways. This will then add up to 160Ah for each pair (wired in parallel). I have a Victron Energy Centaur charger which has three outputs delivering 20A charge current for use with batteries rated at 80-200Ah per bank. So, two banks - one charger output to each pair.
(1) this should work, right?
(2) When under way, will the alternators be able to maintain a sufficient charge to the batteries?
I'm looking at using Merlin Powerpack - Deep Cycle / mulit purpose battery 15-1024, rated 86Ah.
http://www.power-store.com/view-item.asp?itemid=1668&id=215&
(3) Is this a good choice, or is there better (bearing in mind that I want to keep costs down where I can) ?
Cheers! /forums/images/graemlins/smirk.gif
