Murv
I need to replace two of my start/leisure batteries.
Boat: 1989 Fairline Turbo 30 with 2 X TAMD61A's
The configuration is 4 batteries, with two sets of two for each engine.
The starboard engine bank only starts the engine, the port bank starts the port engine but also provides the leisure source.
After some serious abuse (running almost completely flat on at least 3 occasions) and 4 years of use, the port/leisure set are fairly clapped out.
They still start the engine, but it turns noticeably slower than the starboard one and don't have sufficient power to start the engine after 12-16 hours of running the fridge/LED lighting.
I don't want (can't afford) to reconfigure the entire layout so just want to replace the two batteries.
So, what to get?
Our power requirements are fairly low, all lighting is LED, the biggest drain is the (30 year old) compressor type fridge. We also have a 1500W inverter which is only used to power a coffee grinder and a 40W TV for maybe a couple of hours/day and the goal is to be able to manage 3 days off-grid with the assistance of a 100W solar panel to slow down the drain without causing damage to the batteries.
Current batteries are type 664, I don't know the capacity but am guessing around 110-130AH and are 850CCA.
I can't find out what the characteristics of a 664 are, they seem to be just classed as "heavy duty."
The advantages of the 664's are that they're cheap, and have a high CCA rating but I guess that this makes them less suitable as leisure batteries.
Current thinking is to go for AGM dual purpose, which I accept aren't as good at either task as dedicated batteries but might be the best bet for me?
I'm limited by the size, the batteries all sit in a box, they're a very snug fit and there really isn't anywhere else to put them.
I'm also limited by the battery charger, this is a Studer MBC 12-30/3 which is a 3 output, 12V 30 amp 3 phase unit.
It's rated as having a battery capacity of 140 (division sign) 300 AH which I assume is the range?
If so, I'm also assuming (the manual doesn't make it clear) that each output will charge up to 300AH so I could get 2 x batteries up to 150AH assuming they'll fit in the box.
Any thoughts? I don't see any sense in paying for top of the range type batteries when I could just get another pair of 664's for ~ £200 and just replace them every 3 years, just wondering if there is a more suitable option given the criteria above.
So, what to get?
