sarabande
Is she set up for thole pins, gig-style ?
A question out of curiosity, if I may.
Here in Malta one only sees rowlocks on some inflatables. Traditional boats use a single thole pin in front of which the oar is fitted, secured with a plaited strop of three strands of hemp (treated with some kind of tar and smelling of creosote) that is then lubricated with grease or fat. There is a special knot to make a double loop in this strop; secure, easily adjustable and its construction is based upon a 'lark's head'.
My question is this: "Do you use a similar system in your country? If so, what is it called? If not, how do you secure the oar to the pin?
Thanks.
I've always thought that should be a thing, here, but never seen it, except when a rowlock was lost and the oar was tied to the hole. There were boats with a sculling notch, raised wood with an open topped hole in each berth, only seen here on the transom for sculling. Our oars are allowed to rattle back and forth between two pins
Well done keeping the boat in use! You mention rowing 'randan' - a system with three oars men, bow and stroke pulling one oar each and the middle man pulling two oars, thus balancing the 'pull' on each side of the boat. Something I've often wondered - do you need a cox to steer or does the middle oarsman also control the course of the boat? Sounds like hard work for the middle man whatever!
Here is a photo that shows how the oar is held to the thole pin:
And here you can see the oars in operation (you can skip the first 30 seconds)
If you are interested in how the knot of the strop is tied I can take a couple of photos later.
There must be an alternative in synthetic.
