MarkJohnson12345
Just fitting my new alternator, replacing the old Sevy Marchal.
Three of the four connections are obvious (I hope)
The positive, and negative and the green field connector are indentified.
At the same time I am re-fitting the Adverc charger control.
This identifies the 4th connection as a low current output called one of the following -- Ind, D+,61, Lterminal.
Lookiing at the picture above, the Positive Negative and field seem to be obvious.
Its this low current output that I am not clever enough (I wish) to indentify.
The Adverc wiring diagram might be indicating its the AC TAP connector.
But their diagram is really only for fitting their system, and not fitting the alternator to the engine.
I can ring Adverc on Monday, but hope to get it up an srunning before then.
Any ideas?
