Karnic
Hi Guys
Need some advise and would appreciate your kind and sincere help. Want to drill some holes on my deck to install cleats and deck hinges ( Bimini ). Would use bolt and nuts, with backing plates and washers. As I am not using the self tapping screws, is it ok to drill a slightly ( FEW mms) larger diameter than the bolt or I would have to countersink the hole as well? Also some friend of mine recommended drilling in reverse mode but again as I am using bolts and nuts instead of self tapping I think a slightly larger hole than the bolt would do the job and avoid the cracks in gelcoat.
Thanks for your feedback.
