Avocet
Nah - I doubt I'll get 30-odd pages out of it!
+1 - Kipor 3000Ti - superb engineering. precision castings on engine - nicely forged crank and con rod (yes I have had the sump off out of curiosity to see what was inside) - workshop manual available as are spares if needed - so far all I have changed on mine is the spark plug and oil.Don't be wary, I've got two:
Kipor IG1000 on boat: http://amzn.to/QQenXG
Kipor IG2600 at home: http://amzn.to/QQeMtl
They also do a 2000W: Kipor IG2000 http://amzn.to/1xhLt24
Think your 800watt microwave will use 1600 watts, check the info plate for the full load rating.
Mind you I also have a 5kva diesel jobby - unfortunately it is hand crank to start - fortunately it usually starts first or second attempt. Runs the house nicely - lights, boiler, microwave, toaster, TV etc (and it runs on RED)
If that were the case then the battery wouldn't know anything about it.Just another question... Would an ordinary lead acid (car) battery be likely to suffer any ill effects with an alternator pumping (say) 60A into it and an inverter pulling 60A out of it simultaneously for (say) up to 5 minutes at a time?
Starter motor type situation thenMost of the time, I imagine it would be half that or less. The way I'd imagine it working would be that there would be short periods (under a minute) where the inverter would pull more from the battery (say 80 or even 100A), where, obviously, there would be a net discharge even with the alternator maxxed-out.
I would think so yes....Then there would be a period where the current draw would fall below that which the alternator(s) could supply, and it would start to re-charge. Then there would be the majority of time when the discharge rate was well within what the alternator could manage and (I assume) all would be well.
But it's not flowing through it is it - the battery is a stabilizing voltage source, that is all ... the current will go from the alternator to the kit you're powering - it just happens that you've got a battery in parallel - do the circuit diagram...Really?! I can see why you're saying that, but I just assumed that having that much "energy" flowing through it might have SOME sort of effect?
This thread reminds me of this one..
http://www.ybw.com/forums/showthread.php?241749-Micro-12v-Generator-Project
