duke
Hi,
recently purchase Nasa clipper navtex.
I cut the cable plug approx. 1 metre from inner end to feed the cable through bulkheads and then hopefully reconnect at the chart table.
The antenna aeriel cable is approx. 10 metres long -- 75 ohm coaxial.
However the cable supplied with the Nasa clipper navtex is smaller in diameter than standard 75 ohm cable ( clipper navtex cable diameter is more like satellite dish cable).
Also the central wire is "stranded" rather than a single solid wire.
I'm finding it impossibe to get a good rejoin of this cable.
Cant find a connector to join this cable - the "stranded" central core is very fragile and breaks very easily.
I've tried using a " satellite cable connecting kit' but this is designed for use with a single( solid wire) central core and the "stranded" core won't push into it and just breaks.
Has anyone had a similar problem and any suggestions as to solution.
Am seriously thinking of purchasing new antenna and drilling bigger holes in bulkheads to accomodate cable plug and avoid cutting it.
Regards,
Duke.
Regards,
Duke.
