KINGFISHER 8
......... no problem with all the other instruments ... first thing to try? - IIRC there's a rechargeable battery inside - maybe this needs replacing? Dunno! Don't want to have to call the man if it's simple!
Manufacturer then? A better description? You must admit it's a bit hard to diagnose if you don't tell anyone what machine you're talking about.
With 4 buttons along the bottom I'd hazard a guess at a NASA Pro, but could be anything really.
...In the past Nasa Marine have been good on repair of products, quick turnround and comparativey cheap,.....The down side is their products seem to need a bit more repair than some.
I have one that also went kaput after being left unused for 3 months. In my case there was a single line across the screen, and if I left the set turned on for 2 days it eventually started working, though when turned off it instantly failed again. Like others, I assumed it was a bettery, but NASA Marine reckoned it was a failure of the LCD module. They offered to fix it, but I need to get the unit back to them, and the boat is in Spain and I'm in UK!
In the past Nasa Marine have been good on repair of products, quick turnround and comparativey cheap, so its probably worth at least an e-mail or phone call to them. The down side is their products seem to need a bit more repair than some.
Mine has just been sent back to NASA for that very reason a duff LCD screen ,quoted £34+vat +carriage to fix(at cost price)
