Navman Transponder-Too Noisy
mikebecker911
12 Jun 2007
Greetings,
I'm a relatively new boat owner, a 19' fiberglass over wood open skiff, 40 hp outboard. Last weekend I installed a Navman Fish 4500. To me the transponder seems abnormally loud. While at idle, one can hear a very noticable, "pop-pop-pop...." from the transponder. I realize it's sending out a signal (sonar ?) to read the depth, but just how loud, or prominent should the sound be. I frankly thought it would be essentiall silent.
Thank you in advance for any help.
Mike Becker - Kittery, Maine
Sneds
26 Feb 2007
Bristol
Intersting one this.
Does the frequency of the "pop" increase with engine revs? If so it could be a suppresion problem, but most odd!
mikebecker911
12 Jun 2007
Well then, it seems that in an open skiff, with the transponder attached to the transom 6 feet away, and perhaps 8 inches below the surface, the "pop-pop-pop" of the signals will be quite audible.
Thanks to all who responded, I appreciate the help.
-Mike Becker - Kittery, Maine
Major Catastrophe
31 May 2005
Next weekend, I will stick the Navman on, without the engine running, and listen to hear how loud it is. As my Fish is hooked up to the engine ignition, to record engine hours, I don't usually have it turned on when the engine isn't running.
