Navman Tracker 5500 internal battery
DaveS
25 Aug 2004
West Coast of Scotland
My Tracker 5500 lost its memory: all settings and way points disappeared when external power was switched off. The only thread I could find on replacing the battery was this: http://www.ybw.com/forums/showthread.php?134574-Navman-5500-chartplotter-Battery-change from 10 years ago but it seemed a bit inconclusive. I thought that it might be helpful to record how I got on.
The hardest part was undoing the case fixing screws. They have very small hex sockets, smaller than any of my allan keys or hex drivers. I eventually found a 1/16" hex driver which worked, but it was a slightly loose fit: I think the correct size might be 1.75mm. The two fixing nuts for the connection sockets also have to come off to open the case; I also disconnected the antenna socket, but that's perhaps not strictly necessary since it is connected by a flexible cable inside. Opening the case reveals two circuit boards held together with screws and a soldered tag. Separating them gives access to the mounting holes for the internal battery. It was a 25mm diameter lithium 3V cell marked CR245 which showed a healthy voltage, but two of its three mounting feet were separated from the circuit board. Gentle wiggling made the third fall out too. Re-soldering was fairly straightforward, as was reassembly. The fixing screws are tapped into plastic so, just as with toilet pump screws, the technique is to rotate them anti-clockwise until they drop into the thread, then tighten. 11 of the 12 went fully home while the twelfth's hex socket got rounded: a better fitting hex driver would probably have prevented this.
The plotter now works correctly, and I've re-entered more than half my way points - a very boring job. (I know that it's possible to buy a C-map gizmo that allows way points to be transferred between plotter and computer, but I don't have one.)
Thanks for posting that. I have an aging 6500 as a backup plotter so could suffer the same at anytime.
Kits of very small assorted drivers are sold for use in the repair of mobile phones and tablets.
DaveS, sorry for the thread drift - do you keep your charts up to date on your Navman 5500 (I have the same same model but it is out of date). Can you buy a card with charts for it?
I regret to say I don't. I could, by getting new cards (it uses Cmap NT) but I've gone for the cheaper option of using Memory Map on a tablet with all UK admiralty charts which costs around £20 for an annual update, and I also have Antares charts on it.
I have a series of photos of the repair of a navman 5505 showing the torx size etc. Is there a way of getting them on here apart from a lengthy session on photobucket?
Photobucket is probably the best bet.
To be honest, Flickr is very easy. Set up an Flickr account, download the uploader App for whatever system is in use, drag and drop photos into the uploader App, go to Flickr, click on the image, copy the BBcode in the share menu, paste it into the forum and delete the parts of the BB code on either side of
