NAVMAN Spares....Help
comino
Active Member
17 Jun 2008
Lefkas Marina
www.yachtcomino.weebly.com
I'm hoping someone can point me in the right direction for NAVMAN chartplotter spares. Mine keeps dropping the satellite connection just as I'm navigating somewhere tricky (such as Cape Trafalgar recently). I would like to replace the dome antenna, fitted on the pushpit, but can't find a supplier. The model is 5605. Thanks in advance.
If its like my Navman plotter the aerial comes with a little screw in doobri, which screws into the only whatnot it will fit into on the back of the plotter, sorry about the technical terms :)
My navman aerial on my last boat appeared to be defective. I traced it to the plug that went into the plotter. Navman/Plastimo (at that time) said that it was dead, and I needed to replace. I wet down to maplin and got a new plug and some solder and heatshrink. chopped a couple of inches of the lead from the aerial and it worked better than before.
Cheaper than most other alternatives!
