Navico RT6500S
Rustyknight
13 Aug 2003
Having had years of trouble free use from my Navico VHF, it has at long last decided to stop transmitting. I've traced the fault to some broken wires in the microphone lead...... the wires having parted company from the soldered pins in the microphone 6 pin socket.
Six different coloured wires, six pins numbered from 1 to 6..... but with nothing in the manual saying which wire attaches to which pin.
If anyone knows, I'd be obliged if they can share the info!
pvb
UK East Coast
Long shot...
I wonder whether the wiring on the other side of the connection is similarly colour-coded? Might be an easy way to solve the problem.
Rustyknight
13 Aug 2003
Thanks for that Phil. I've found a website for Simrad (it seems they're part of B&G) with an e-mail addy for customer support.
Rustyknight
13 Aug 2003
Re: Long shot...
I took the casing apart, but the connections go straight into a printed circuit board /forums/images/graemlins/confused.gif
aztec
10 Oct 2001
Poole Dorset
iff you get stuck, iv'e recently fitted a new mic to one.. (i think).. need to check the numbers.
i'll have a look tommorrow morning, pm me if you don't get any joy.
steve.
Rustyknight
13 Aug 2003
Curiously, although the lead is made up of 6 different coloured wires + what appears to be a screen, only 4 of them are connected in the fist mike end.... the others appear to be spare!
Blue and white to the PTT switch, red and possibly the screen to the microphone itself.
I suppose that cuts down the number of possible mistakes at the other end! /forums/images/graemlins/blush.gif
aztec
10 Oct 2001
Poole Dorset
got a strange feeling that the reason for that is, the possiblility of fitting a telephone style handset...
like i said i cant remember which one it was.. i seem to have quite a collection of VHF's lurking round...
aztec
10 Oct 2001
Poole Dorset
just checked.... ain't i good to you??
1=sheild
2=green
3=orange
4=white
5=red
6=black
green and white seem to go to the speaker on the telephone handset.
Rustyknight
13 Aug 2003
Steve,
Many thanks for that. I'll be down in Poole again tomorrow with my soldering iron and see what happens!
Mike.
Pyro
30 Apr 2017
I've a Navico RT6500 VHF and while cleaning the channel change button contacts with the set split in two, managed to (a) disconnect (break away) the black wire from behind the mic connector, and (b) also break what appears to be a resistor on the back of the mic connector. Would anybody be able to tell me the pin-out colours from the mic connector inside the set (or maybe post some photos of this, ideally identifying the resistor colour bands)?
agurney
10 Jun 2009
agurney.com
Use Google to search for "RT6500_Service_Manual.pdf"
