Nav Lights on 20ft
fellinagen
21 Jul 2004
SW Wales
I have a 20ft Vivacity and was planning to fit full navigation lights even though they aren't strictly required.
Now I think about it, would nav lights be seen as helpful (ie. a more comprehensive lighting setup than is required) or perceived as misleading in that under lights people might be confused thinking she is a larger vessel than she is?
So coll regs says I don't need them. But would it be good or bad to have them?
<hr width=100% size=1>If you're not confused, you're not paying attention.
Talbot
23 Aug 2003
Brighton, UK
certainly better to have full nav lights, but dont need to be kingsize (aquasignal 25 series are perfectly satisfactory) and would suggest that a combined port/stbd would be a good idea if you can fit them. power consumption will be an issue thus needs to be considered.
Nickel
8 Nov 2003
Solent
The colregs have to have a lower limit, below which they do not impose compliance with the standard lighting plan, otherwise even tenders or inflatables would have to be lit. But if you are planning to install the standard nav lights for a small sailing vessel [eg mast tricolour, pulpit bicolour, steaming light and stern light] then I reckon its beyond doubt that you will be helping yourself and others at night time and in poor visibility.
<hr width=100% size=1>Nickel
Being paranoid simply means - having all the facts.
fellinagen
21 Jul 2004
SW Wales
Thanks for the info. I was curious after a recent thread where the common feeling was that over lighting was as bad/worse than wrong lighting.
On the subject of power consumption - anyone tried these little solar panels for 12v trickle charging? (ebay £20 ish). Do they work or are they just a conversation peice?
sailorbaz
22 Apr 2002
Bald Knob, Queensland, Australia
I bought one last season and because it wasn't waterproof, I dismantled it and then reassembled it with the translucent mastic used for sticking aquariums together. I then fixed it with screws to a Perspex backplate and sealed it to that. You need to pay special attention to the cable entry - mine leaked the first time!
I stuck two strips of Velcro on the back and the other strips on the front hatch.
I fitted a cig. lighter socket in the front cabin connected directly to the battery terminals via a fuse.
I leave it on the boat all the time except when sailing - the genoa sheets catch on it. It keeps the battery fully charged but then my boat is on Lake Geneva. It might not be as efficient in the UK.
Hope this helps
Sailorbaz
snowleopard
Oxford
on a sonata i owned the sole nav lights were a combined tricolour and all-round white. it meant i could have proper nav lights when sailing and the minimum white when motoring. i would have preferred to have a 'proper' set but it was a good compromise.
duncan
Home mid Kent - Boat @ Poole
I agree - it enables you to indicate your status pretty well to other craft and on the assumption that you don't have a 200hp OB the fact that your direction cannot be quickly accertained when you are under power isn't going to be that significant to other powered craft.
<hr width=100% size=1>madesco madidum ..../forums/images/icons/smile.gif
dickh
8 Feb 2002
Suffolk
Definately go for the full set - on my Vivacity 20 some years ago, I had Bicolour on the Pilpit; Stern Light on the pushpit; Steaming Light at the crosstrees; and a Tricolour at the masthead with a Paraffin lamp for anchoring. So I was fully covered for all situations. You can get the Aquasignal series 25 or equivalents on eBay at a reasonable cost.
<hr width=100% size=1>dickh
I'd rather be sailing... :) /forums/images/icons/smile.gif
Mhvoiceuk
9 Oct 2003
Brighton
I have an Islander 23 (which is actually 22'6" and therefore right on the borderline) and I recently fitted a full set of lights. It certainly makes me feel a little more confident about sailing at night, particularly under sail with the trilight on. The tricolor says that I'm definitely a yacht and I'm definitely under sail. I've also got a 5 watt solar panel which I screwed to the top half of my washboards. It keeps the battery topped up and I had no problems last season or this with flat batteries.
AndrewB
7 Jun 2001
Dover/Corfu
The prime consideration is to be seen.
Better to have one decent all-round 25w white light that is visible for two miles, than a whole collection of dinky low-powered red-and-greens.
Gunfleet
1 Jan 2002
Orwell
Under 12M you can have white at the top all round and red/green at the bow for motoring, white at the stern and red/green at the bow for sailing, so you never need have more than 2 bulbs alight. Lots of people, including one yachtmaster instructor I met, are unaware this is the case but its in your copy of Reeds
peterb
Radlett, Herts
Rule 25(d)(i): A sailing vessel of less than 7 metres in length shall, if practicable, exhibit the lights prescribed in (a) or (b) of this Rule, but if she does not......
You obviously think it is practicable to fit the lights, so surely the "shall" means that it is compulsory, and colregs say that you do need them?
FullCircle
19 Nov 2003
On my 22 footer -
I fitted the Lalizas 12M masthead tricolour rated at 2 Nautical Miles carrying 10w bulb, and a Crosstrees located 12m White for Motoring. Anchoring is done by hoisting a Hurricane lamp into the crosstrees.
It saves on the electricity, as I only have 5A charging, and the boat is on a swinging mooring. I also have a 5w solar panel, 20 something quid from Tomjo Marine who do the Boat jumbles.
Jim
<hr width=100% size=1>Our engine will never wear out - it only runs for 5 mins before packing it in again.
Pelican
6 Dec 2001
Geneva, Switzerland
Re: for sailorbaz
Where are you moored on lake Geneva? I'm in the Creux-de-Genthod - how about meeting up somewhere for a drink? - have never met any other formites on the lake!
Fair winds
Pelican
sailorbaz
22 Apr 2002
Re: for pelican
Until this season we were in La Pichette near Vevey. We live in Valais and have been on the waiting list for a place in Le Bouveret for 9 years! We finally got a place this year, so that's where we are now. We haven't yet been down your end.
We occasionally go to Rolle or Port Ripaille on the French side but we are planning a tour of the Lake for our main holiday next year.
Please PM me and we can keep in touch.
Sailorbaz
most have them, many don't use 'em.
Its your choice ..... I have'em, but they need replacement and I am seriously thinking about portable battery type instead of the fixed 12V type that has failed on my boat. The old ones are fitted to nice brackets on pulpit etc. - but thats as far as they go - years of spray and exposure have led to discoloured lenses, bad wiring and loss of use.
As to anchor light ...... stick a lamp up the flag halyard.
Still got to decide what to do with the mast head light ......
<hr width=100% size=1>Nigel ... and of course Yahoo groups :
http://groups.yahoo.com/group/gps-navigator/
Local car shop - 24.99
Have two of 'em .... ones just packed up after 2 yrs on cabin top ..... probably because of strating engine with it still plugged in !
But they are trickle jobs for keeping car batterys topped up when car stands .... worked for me.
I shall buy another later.
oldharry
30 May 2001
Which is safer: for other craft to know that there is 'something' there (i.e. all round white), or for others not only to know where you are, but which way you are going , whether you are under power or sail, and which of you should give way under Colregs?
jimbouy
21 Aug 2003
Sailing.. Solent. Home..Bucks
www.bluemoonlight.co.uk
I fitted a £40 5W panel to my Leisure 17, fixed to the aft locker lid. Which has kept battery fully charged.
But only powering 2x instruments and VHF
The panel was from CPC.
<hr width=100% size=1> "It is a pleasure to give advice, humiliating to need it, normal to ignore it"
