Maybe silly. What does the intruction "lashing the tiller to leeward" mean? The rudder is then to windward??
The tiller is set to turn the boat into the wind against the pressure of the backed jib. As the boat turns, the main spills a little wind and allows the jib to turn her away from the wind. As this happens, the main fills again, giving a little forward motion, which allows the rudder to turn her back upwind, when the whole sequence starts again. That's "heaving to" as conventionally practised.
to save winching the jib up to windward tack and leave the jib sheeted backed on the windward side ,tie the tiller to leeward .Some boats need the main eased a bit others need it tight in.
your absolutly correct!!
Far better to heav too when heaving up!! the motions far calmer. But hasent everyone had to stop from time to time ? If only for a rest from the motion to make a cup of tea and make an SSB call??
I once hove to for 6+ hours between messina and Malta just to rest and enjoy the seascape in a f 4/5 and less Italy has very good food and wine!
I wasent ill just very tired i kept falling asleep!! Not enough exersise.
So -- if I "lash the tiller to leeward" the rudder blade is effectively to WINDWARD right?
The term then relates to where I move the tiller to and not where the rudder blade goes ?!
In other words. If I had a wheel I would turn it to WINDWARD to achieve the same thing??
I used to do it regularly to prepare food and to brew some coffee. Nowadays I don't do it so often because my present boat has a tillerpilot.
Be careful when heaving-to between Messina and Malta, especially if you are very close to the Sicilian coast, especially in the region of Siracusa. The gregale (north-east wind) can become quite nasty very quickly, usually in the afternoon.
