greggron
My Nasa Target echo sounder goes berserk when my engine (9.9AE Yamaha inc. alternator) is on, otherwise depth readings are fine. The transducer is fitted as far away from the engine as it can be on a 22 footer and has not been cut. I realise that the oil around the tranducer head might need topping up/changing as the effect might be caused by vibration.
How do I do that (does it just pull out - I have no manual)?
What oil should I be using?
If that doesn't work, I have heard that you can fix a capacitor between the connections on the back of the display unit which will cut out electrical interference.
What specification should I use?
How do I do it?
Possibly naive questions I know but any help appreciated.
Greg
How do I do it?
Greg
