emearg
Hi all,
I have a wee problem with my sadler 32. I noted that my log tube had a wee leak so when I lifted out I would investigate it. ……………..went into the locker and removed the big plastic nut from the log tube, yes it should be epoxied in…it wasn’t!!!!!!!!!!! Next I thought I would remove the tube housing, expecting myself to ruin it when I removed it, imagine the shock when it just falls out and even worse it was held in with ordinary house hold silicon…and worse again the diameter of the log tube is approx 40.5 mm and the hole in the boat was 50.5mm in diameter…….and even worse again the big plastic nut only had a diameter of 51mm…how I never sunk my boat I will never know. But anyway…..
The questions I have to ask are.
1. Why was the hole in the hull so big…was there any old log in there which had a different diameter or was it just cowboyed.
2. If I am now going to fix it, is it best just to re epoxy the hole and redrill the correct size or would sicaflex fix it……think the best way would be to epoxy it and re drill.
3. If I am going to epoxy it then I have a counter bored the hole from the inside so that the epoxy bung will not fall through the hull, should I then do the same for outside the hull so the epoxy “bung” will not fall out into the boat. How do I make sure it is properly “keyed” into the hull……..a 50mm hole lets in a lot of water.
Opinions and answers welcome.
Graeme.
Graeme.
