Petronella
Our trusty (yes, it's been fine for 6 years) NASA Clipper wind instrument gave up the ghost whilst crossing from Lanzarote to St Maarten. A wave on the instrument and a gust of 47k at the same time finally did for it but which end is the problem?
At the masthead the cups are still there and rotating as usual and the direction indicator is a bit sticky but still rotating as it has been for a couple of years. The display unit sort of worked for a couple more days after the initial problem but went up to 99k then down to zero then worked for a bit then did its rotations as if it had just been switched on. Now it just reads "0". After some attempts to show the direction that part of the display has finally stuck in one position even though the vane is rotating.
My question is "Is this indicative of a masthead problem or a display unit issue?"
Thanks.
Thanks.
