NASA Clipper depth transducer oil??
tonygibbs
3 Feb 2014
South Lanarkshire
Hello all, I broke the plastic pipe where the transducer fits from the hull. Noticed that there was some kind of oil in the bilge. Easy enough to re-attach tho' I've been told that ordinary vegetable oil would be ok to use. Is this correct, if not what oil should I use?
GrahamM376
30 Oct 2010
Swing mooring Faro
Easiest way is to clean the oil off the bilge, throw the pipe away and stick the transducer on with a gob of silicone, epoxy or polyester. I used some of the green fiberglass filler which comes in a tube.
rob2
23 Aug 2005
Hampshire UK
I believe the recomendation from Nasa is "mineral oil". That got a rather bemused look from my local chemist who found several possibles from a Google search! In reality i think most people use whatever cooking oil they have on board. The important thing is not to use any synthetic stuff which might attack the plastic.
Rob.
fergie_mac66
28 Jun 2009
south yorks
baby oil is good. Dont use olive oil though, it cloudys up in low temps .. A gob of silicon works carefull no bubbles! though .If you want to test for position ie bubles in GRP can cause problems you can use a plastic bag with water, wedge it in place to test the position works . Silicon can be cut if needs must to move.Epoxy or polyester make it hard to move.
erbster
21 Apr 2012
Midlands
travellingaurora.wordpress.com
I have seen silicone recommended several times and attached mine like that, but got lots of odd readings. I asked Nasa about this and they told me that Silicone is elastic, so absorbs some of the energy of the ultrasound, thereby reducing sensitivity. I changed to the "oil tube" arrangement (more faff, I grant you) and the depth readings seem more reliable. I was too chicken to epoxy the transducer to the hull in case I made a mistake (no coming back from that).
+1 for vegetable oil. I used rape seed oil from the kitchen.
MM5AHO
1 Oct 2007
Central Scotland
While on this instrument...
I like the look of the nice big display and it matches an existing GPS repeater.
But I have Airmar instruments now feeding an ST30 Bidata.
Are my existing instruments compatible with the NASA head unit/display?
VicS
13 Jul 2002
caster oil is the preferred oil as per the nasa info, you can buy it from a pharmacy is small quantities
castor oil been in the mounting tube for my ( Seafarer) transducer quite happily for 35 years
(nb caster sugar but castor oil)
bigmac91
20 Mar 2012
North East
I have used vegetable oil in a plastic pipe epoxied to the hull for the last 2 years with great readings and no problems
Hope this helps
Les
