Scubadoo
Just fitted last weekend NASA BM1 battery monitor, installed no problems and seems to be working fine. My only question, the black negative cable supplied that connects to the Shunt and the Battery terminal looks a lot thinner than my existing battery negative cables. Should I be concerned and consider installing a larger diameter cable to match my existing negative cables, or what have others done. Mine is a simple set-up 1 x 125amp battery (leisure), the starter battery is not connected to the BM1.
