lumphammer
I have been thinking of getting one of these, but would like to find out how best to connect it in the standard setup with two batteries and a 1-2-both switch.
I am looking at putting the shunt in the common negative return, so it will monitor the current drain of whatever batteries are connected.
Does this make sense? Is the shunt likely to be damaged by the engine starting current, which I guess could be more than 100A?
Any other thoughts on how best to set this up gratefully received.
