NASA AIS Radar - Best settings
Gubbo
17 Jun 2001
Woodbridge
www.sailpast.co.uk
Having recently installed a NASA AIS Radar, I was most unimpressed with the minimalist instrution booklet when it came to the attributes of the various settings.
Having sailed last weekend in the Harwich area, it collected lots of information, but I found that the validity was somewhat hit and miss. For example it would track a ship to a point then the display would become "static" even though the vessel was clearly steaming onwards. It was as if the unit had become bored with that particular ship and didn't want to listen to it any longer!
Can you advise what settings you use for the most reliable results. In particular I'm interested in whether you select channel A, B, or alternating A/B?. What threshold level do you have? Which range and update rate gives the most consistant results? How long should I have to wait between updates from ships on the move? Is it just me or do some ships transmit incorrect status messages via AIS (ie moored when steaming or vice versa)?
For info, my antenna is mounted about 10' above the waterline and the ships I was interested in were only between half and three miles away. The ships concerned are North sea ferries and large container vessels so clearly within the AIS class A requirements. I also have proper radar fitted and am aware of the limitations of the AIS unit, but would still like to get the best from it.
many thanks
Gubbo
The instructions are indeed somewhat primitive. My NASA unit cannot alternate between A and B channel - and it didn't make any difference when I tried the two. If you lose contact that early, you should look at your antenna connections. If you look at the screen that shows the threshold, you can see the signals coming in. Will give you an idea how strong they are and if you need to adjust. I can follow ships (antenna two and half feet above waterline) till about 10 - 12 miles. Refreshment rate is in the AIS system (don't recall, but when sailing it's quite fast), not in the unit. And yes, ships are sometimes sailing when they are anchored and the other way around - so quite often they forget to change the transceiver, I guess.
Chris
