lustyd
I’m planning the install of my new NAC3 autopilot and looking at cables which seem to need to be round to seal in the rubber grommets on the unit. It’ll drive a Raymarine Type 1 linear unit which seems to top out at 3A but I’ve found some Oceanflex 2x2.5mm and 3x2.5mm 29A cable which looks a reasonable fit. The NAC is rated higher than this at 30-50A. I’m thinking to put a fuse on rated to the cable and assume the load will never go higher with this drive unit. Steering is very light anyway so doubt I’ll approach the max amps of the drive unit.
alternative is larger cable but individual cores which feels like a faff to install and will create unnecessary wiring mess.
anyone fitted similar or have thoughts on the plan? Termination is in some nice screw terminal plugs so it’s all bare wire including the NMEA.
