single
At the weekend i checked the engine over before a planned 6hr motor and discovered water in the oil. The dipstick was grey but still oil viscosity like, but the filler cap was like grey yoghurt. I did a few oil/filter changes and all looked good so went off cruising checking it every hour. All is still perfect after about 8 or 9 hours running so what caused it? The fresh water side of the engine hasn't lost a drop so it must have been sea water. The exhaust has an anti-syphon valve fitted. If while cranking i had filled the exhaust, surely it would have hydraulically locked the engine? Maybe the jabsco seawater pump seals leaking? Any other suggestions? (Thornycroft T-95) Ps. On the first oil change there was about 0.5ltr of 'extra fluid' in the sump.
