Mystery objects - anyone recognise this?
Ardenfour
7 Feb 2004
Port Bannatyne
I,m getting very erratic depth readings from the sounder NASA Clipper - mostly displays 'OUT' but occasionally jumping numbers and sometimes an actual depth. Been tracing wiring and came acrossobject in pictures. There are two of them, p + s, and two of the connection boxes. They seem to lead to a third box containing a mercury tilt switch, and then to the display head. But I also have a third transducer with coax going to it, original to the boat, encased in grp. Any ideas? I've fitted a new coax plug at the display end, the old one was a tv coax and the core and braid were shorting.View attachment 52671View attachment 52670
There used to be a vogue for fitting a log transducer on each side of the boat, and automatically selecting the leeward one for each tack via a tilt switch. The idea being increased accuracy away from the surface turbulence. I've even seen the wiring for this on a 600 ton sailing ship, though the switch had been bypassed to run one transducer all the time. Not uncommon, I suspect.
No doubt that's what's going on here.
cheers pete. Nothing to do with sounder then. Will look again but i'm pretty sure the output from the tilt switch goes to the sounder
I suppose the same principle could be applied to a sounder. But the transducer device, though it looks like nothing I've ever seen before, seems more like a log than a sounder. It seems to be removable, and/or retractable without removing, which makes sense for cleaning a paddle-wheel but is irrelevant to a sounder.
The box in the second picture clearly says "log" and "speed".
