Mystery Object on boat.
oldgit
6 Nov 2001
Medway
While attempting to mend other stuff found this in the engine compartment.
Anybody know what it is or its purpose in life.
Absolutely no info on it other than the the chap who installed it...somebody called "Paul"
Chiara’s slave
14 Apr 2022
Western Solent
It wouldn’t be a proper used boat without a few deeply hidden mystery objects. I always open and peer into every sigle explorable compartment once in possession, you never know what you’ll find, except that it will be unexpected. I found 19kg of lead in my forward collision compartment on board Chiara. Presumably to counter the effects of storing the anchors in the lazarette instead of the anchor locker. Theres no accounting for some folk.
LittleSister
12 Nov 2007
You need those to balance out the parts you know you must have for things to function, but can't find!
(In my case I know there must be charge-splitting diodes somewhere between the alternator and the batteries, but haven't found them yet.)
DownWest
25 Dec 2007
S.W. France
Acting as the 'slightly knowledable' friend on a boat inspection, bunch of rocket line projectiles in the aft locker. Well out of date..
Parabordi
22 Apr 2011
I got one of them too, saves prop fizzing away
oldgit
6 Nov 2001
Medway
When the short lived period of elation after purchase has evaporated and when starting to wonder exactly what you bought.
My AIS stopped working.
It became fairly obvious that the automatic aerial switching thingy had failed, either through fatigue or possibly my fiddling with the chartplotter.
Called in the local Raymarine electronics wizard who did his best, but failed to resolve anything.
He suggested to find the magic box and do a check or two ie. was there 12V getting to it.
Dead easy eh..., just follow the antenna cables and wiring.
Several days later after dismantling most of the boat, admitted defeat and gave up.
A replacement antenna switch would anyway cost an eyewatering amount, so simply added a dedicated third aerial for the AIS and directly connected the existing aerial to the VHF radio.
Never have found the location of the non functioning AIS switching unit.
Then the fluxgate failed. Again searched in vain for in location, again gave up but far more quickly this time .
Bought a "new to me" fluxgate installed it with new wiring and Hey Presto all working again.
About 6 months later discovered the duff fluxgate hidden away in a bilge.
A bilge pump had failed allowing the bilge to fill therebye drowning the fluxgate.
After bringing to boat back to home mooring discovered in the lockers
1 x brand new Icom handportable with GPS thingy
1 x brand new spare starter motor
Several new inflatable lifejackets.
2 x replacement sets deep sea seals in boxes
2 Complete sets of oil/fuel filters and impellers( All genuine no cheap rubbish) and a set of those wooden bung whatsits.
1 complete set of engine anodes.
Daydream believer
6 Oct 2012
Southminster, essex
What about the 5Kg weed, & 3 illegal immigrants, that you have not mentioned :unsure:
Refueler
13 Sep 2008
Far away from hooray henrys
Cheers you learn somethin every day.
One less mystery box.
You're lucky to have found out so easy !!
My mystery box is still an unknown ...
