eileandour
I have twin Volvo tamd31s fitted to my boat. For a while now I have been starting the starboard engine first then the port because if I ran the port engine only I got a low voltage reading of 12v. but by starting the starboard engine both voltmeters showed 14v. I figured a new alternator was required. Fitted new alternator today but when I turned the port ignition on the warning lights on both port and starboard were lit and the starboard ones stayed on when both engines were running. Curiously if I start the starboard engine first everything is ok and no warning lights come on. Therefore I cannot run the port engine on its own.
Refitted old alternator but the problem persists. Can anyone suggest what is going on? ( I don't think there is a split charger in the wiring) Thanks.
