jeremyshaw
My Spade\'s gone belly up
I had my Spade S140 regalvanised a while ago. Since then we have dragged a few times which we never used to do. A friend advised that regalvanising would have melted the lead in the tip, which would need replacing. Good point!
Recently I watched as the anchor dragged on its side for about 50m on a very good sandy bottom. Not having the weight of lead in the tip was preventing it from turning over, which explained why we had dragged when the wind changed (poor resetting).
Fortunately we have an A140 (alu Spade) as a backup, so that's now doing a fine job. Being lighter it doesn't cut through hard ground as well as the steel one, but that's rarely a problem in the Caribbean.
I asked Spade for advice and they helpfully confirmed:
"Your friend is quite correct, the lead does disappear during the galvanising
process and we advise that it should be removed before galvanising. You
will need to fill the cavity with lead until you reach the shank socket.
(slightly overlapping the shank socket on the bottom and less on the top)."
So if you regalv your Spade, relead it too!
