RIN
I asked the forum for help on what to do with my old 7.5HP Mecrury outboard that I rediscovered at the back of the garage. Many thanks for the replies. I got it kind of working but it needs quite a few new parts which I can order from the US
It got very hot even with the telltale gushing away, so I took off the water cooled exhaust baffle plate. The chambers were pretty clogged and the baffle plate itself was so soft you could almost push a pencil through it. No problem there as I can get a new one.
Problem is that one of the bolts that hold the baffle and casing on to the block sheared off as I was removing it. Annoying but not terminal. I soaked it with penetrating oil and cut a slot on the protruding bit and tried to use screwdriver and grips. No good. Got out my stud removal kit and drilled into the sheared bolt, inserted the removal tool, turned the handle and crack, the tool split off in the bolt flush with the casing.
Now question is Should I give up at this point and bin it? I guess if it was working properly, the OB would be worth around £150 so its probably not worth paying to have the bolt removed, assuming I could find someone to do it - my garage was not interested.
Has anyone got an idea on how to remove it?
