My last ever battery question (for this week!)
bluedragon
7 Apr 2004
Cardiff Bay
If I mix Ah ratings between two service batteries (say 110Ah in parallel with a 135Ah battery), same type wet lead-acid, both new, is there a problem? It's been suggested that the 135Ah might not fully charge as the other will charge quicker and shut-down the charge controller to float voltage. I'm sceptical about this as I think they'll equalise. But...???
pvb
UK East Coast
It'll work fine, so there's no problem.
VicS
13 Jul 2002
the larger one will draw more current than the smaller one so they will reach their max state of charge together.
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
That is correct
They will equalise, but at the capacity of the lower one.
Take an extreme case - say 20Ah and a 130Ah
The 20 will charge up quite quickly and push the terminal voltage up to 14v
The 'smart' charger senses this and goes to float more
The 130 is nowhere near charged, and the 20 hasn't got enough guts to bring the 130 up to capacity.
In the case you site, the capacity difference is not too great, so you wont have a real problem.
bluedragon
7 Apr 2004
Cardiff Bay
Hmmm, some slight difference of opinion here. But won't the fully charged one discharge into the lesser charged one to balance everything up in the case I've mentioned here?
VicS
13 Jul 2002
No it wont.
I could argue that the larger one will hold the voltage down. The smart charger senses this and continues at full charging rate and results in overcharging of the small one.
In reality since they are in parallel they will both have the same voltage at their terminals. They will happily charge together.
pvb
UK East Coast
That is correct
No, that's incorrect. The batteries will take charge current according to their needs. If batteries are connected in parallel, you can't have a situation where one will reach a higher voltage than the other!
bluedragon
7 Apr 2004
Cardiff Bay
I said they were the same type, but that's not strictly true in that one one has filler caps and the other (110Ah) is sealed low-maintenance. Shouldn't make any difference should it, except I can't check the water in the latter?
pvb
UK East Coast
Basically, no. The low-maintenance ones are essentially the same flooded lead-acid construction. I use these in my domestic bank.
LadyInBed
2 Sep 2001
montymariner.co.uk
0511-0702-0211-2545_Businessman_Waving_a_White_Flag_Behind_His_Desk_clipart_image.jpg
