MY FRIDGE!! INDEL"B"(Italian)how can i breath life into her?To cool ?
trouville
N/A
10 Jun 2004
crusing with an Arpège
MY FRIDGE!! INDEL\"B\"(Italian)how can i breath life into her?To cool ?
With all the others haveing fridges mine wasent on,besides Red prefers the tempreture we have(just now)
I had some fish and white fizzy wine i put that in my fridge & switched on.The Amp meter showed about 4 amps,the solar panel was providing more than enough power.I left it running
A couple of hours later the fridge wasent cooler??As its not hot below yet the Wine was OK we could drink it.The fish was moved!
Later i took my "new" Indel"B" apart(caseing off) I turned up the thermastat left it running then it began "bang bang bang" rather than "boop boo^p boop"
Just as if a diesel injection pump hadent any lubrication oil but less metalic in the differant sound
I found a brass pipe with a brass cap the size of a car tyer pump adapter.How can i refill the cooling system??And with what??
Could i pour a butain/propane mix into a bike pump screw the adapter on & pump it in?????Or is it the CFCs i need?
How can i get my fridge back to life?
I only bought her second hand last year about 14 months ago in Livorno
Re: MY FRIDGE!! INDEL\"B\"(Italian)how can i breath life into her?To cool ?
Yes, pour liquid oxygen (From the hospital) into a funnel... into the car tyre valve.. also, add propane and engine oil.. for this, you will need a high pressure regualtor - or, a piece of rubber tubing and some jubilee clips.
Pour celullose thinners over the whole shebang.. (To cool it) whilst you are filling it ...
Test the integrity after 30 seconds with a naked flame..
Not much too it really.
Strontium Nitrate is also good.. add it to photographic flash powder 20 percent SN to 80 percent PFP.. also, Sodium Chlorate and sugar.. mix 1 Kg in a coffe jar, then place near the fridge.. drop a match into it.
if it fails to burn, you have successfuly recharged the unit.
Its sad such dreadful things are now sailing i met him once hes disgusting he picked his nose and wiped it in the seat cover
