Samurai_Dave
I've got a Yamaha 50D two stroke outboard (1990 model) I've had a lot of work done to it to get it into a running condition as it was previously unloved. I've had seven trips to sea with it since its restoration but a new problem is becoming a serious nuisance. The engine starts straight away but even when warm it wont tick over without some extra throttle. When on the water putting it into gear makes it conk out 80% of the time which isn't ideal when launching in a busy river. The carbs have previously been stripped and cleaned and I'm using fresh petrol. When its going the engine is great, it runs very happily. I've put on a new fuel line as the old primer bulb had an air leak but I've still got this problem.
Is there a simple fix to this?
Is there a liquid carb cleaner I can add to the petrol to keep the carb gum free?
Thanks.
Thanks.
