Quidi Vidi
Hi
I am in the process of rewiring "Quidi Vidi" but i don't understand how it has been wired. I want to seperate the batteries and do away with the 1 2 off both switch, install a VSR and seperate battery isolator switches, emergency paralleling will be by a jump lead. I have removed the alternator and was surprised to find there are no cables going from it to the battery or starter. Everything is connected by 1.5mm sq cables except the battery to starter which is 50mm sq. I have found a wiring diagram in the manual which i have attached but it doesn't make sense to me. I would expect the alternator to be connected to the battery by a big cable and the ignition light to be connected to the aux on the alternator. Should i stick with the circuit diagram and use heavier cables or could anyone suggest a simpler layout that i could use?
