seamaster30
Here we go again! More bloody problems
My water pump wont switch off. Water pumps through taps fine, but turn off taps and pump keeps running.
So obviously there is a leak somewhere as the pressure in the piping isn't building up to shut off the pump. While the pump is running I hear running water from the side of the boat. I look over to see a jet of water shooting out the side of the boat![]()
So I trace the pipe and it runs back to the calorifier. Its the pipe that vents from the radiator cap if the pressure builds up to much. So I open the cap to have a look and in a comedy style I get soaked as the pressure in the calorifier shoots water over my face (good job I handn't had the engine running)
So the problem is the radiator cap, it clearly isn't sealing the tank and water is constantly leaking out through the pressure pipe. So I pop back to the Chandlery and buy a new cap. It looks deeper than the older one, but alas it's still leakingIt's better than the old one but water is still leaking out and the pump still running.
So what can I do? fit more washers to the cap to try and seal it? Or is there a special calorifier cap that I need??
Help......![]()
Don't mess with the washers - is the new cap for the right pressure? - if so it sounds like your pressure switch is not working.
