My boat's water ingress problem - an update
Mike_S
10 May 2007
Penarth, Cardiff
My boat\'s water ingress problem - an update
Hello all
Just an update on the problem that led me to my first post on the forum a few weeks back about my leaky Regal 2150 (it's a bit wordy as it's not easy to explain). Well, the repairers *think* they've resolved it after 3 weeks of having every man and his dog looking into her nether regions. After having the drive examined for leaky bellows & seals only to find them OK I'd convinced myself it was coming from the ladder mountings under the platform, but they ruled that one out, thinking instead she had a crack in the hull below the waterline (which really wasn't what I'd wanted to hear).
Anyway, they found a small crack in the internal skin of the boat right at the back, behind a box section that has no access to it from the inside of the boat and this was allowing water in from between the internal & external skins. Obviously they then went hunting for a source and found that the bilge fittings through the side of the hull were loose, in fact very loose, to the extent that every time I fired off the bilge pumps half the water was going back in between the skins and over the course of a couple of days, working it's way back into the bilge under the engine. Couple that with every trip out, when the boat was heeled over onto her starboard side the fittings are close to / under the water allowing more back in between the skins and soon enough we had a bucket of water in there. They also think the side window fittings are allowing rainwater past into this box section but there's not much can be done about that.
So, all the bilge fittings have been changed / retightened up, the small crack filled with sealant and they've installed a 6" dia dinghy hatch into the top of the box section, under the carpet so we can sponge out any water that gets in. They're of the opinion that it'll take a while for it to dry out fully but we can but hope.
I have to admit to being slightly pessimistic about it all and I'm reserving judgement until I've taken it back out to sea to test for anymore water getting through but fingers crossed, it's all OK. Full marks to the repairers though, it's clearly been bugging them as to how it's getting in and I'm grateful they've persevered with it.
Thanks for all the ideas and pointers that came out of my original post though, it was really helpful to a new boater such as myself.
Cheers
Mike.
Re: My boat\'s water ingress problem - an update
Glad to hear you sorted it out. Do remember reading your earlier post but had nothing to contribute.
Are you in the Marina in Penarth as we are?
Excellent - sounds like they've done a good job for you - how about naming them - nothing like a recommendation for other owners in your area. God knows it's hard enough getting someone to turn up when they they say they will !
Adrian
www.cleanandshiny.co.uk
The boat's at Cardiff Bay Yacht Club, down towards Cambrian Marine where she's been for the last 3 weeks. I'll be down there tonight moving her back to the normal mooring unless they've already towed her back. We just happen to live in Penarth.
I've only been in the marina a few times, to do our courses with TBT and to fill the boat up with fuel on Saturday. Usually to be found stooging round the bay & mermaid quay at weekends though, having only had the boat a few weeks the novelty hasn't worn off yet /forums/images/graemlins/grin.gif . Perhaps see you down there ?
The repairers are Cambrian Marine on the River Ely in Cardiff Bay, with the engine / outdrive inspections being done (for nothing) by David at West Point Marine next door. Very friendly bunch.
Will keep an eye out for you and say hello. Would second your recommendations David at West Point Marine is particularly good he has always looked after our boats.
No link just happy customer.
Agree,
Cambrian did a great gel coat repair on my old boat and Dave serviced it. Dave is also always happy to give up some time to advise.
Looks as though Regal are letting their standards slip a bit which is a shame after the great improvements made since my ancient early 1970s Regal appeared on the planet as a prime example of how not to build a boat,what materials to avoid when building one and to try and use designers who may have at some point been on an actual boat. /forums/images/graemlins/smile.gif
Ps.Forty years on still no access to inner hull eh! .......................
