Rivers & creeks
I'm new to hull anodes after many years with outboards and no skin fittings.
The boat has just been lifted out for 3 months and has:
- Large lozenge shaped anode 5 feet from the stern, 20% worn so left unchanged at launch February 2012 - no more discernable degradation on haul out this week.
- Disc anode on steel rudder - new in February 2012 - almost no discernible degradation on haul out
- Pear shaped anode on other side of rudder - reasonable signs of degradation on haul out.
Just to check first - wire should go from engine block (the common ground for the yacht electrics) to the hull anode? It's got two posts, should there be a wire to each or just one?
It is possible to link the rudder back to the engine block - but should I?
Those questions plus the issue of why so little visible signs of degradation in the anodes? BTW we don't yet have a galvanic isolator fitted, we're on 230v permanently when afloat and there are large steel pilings close by.
The prop and rudder showed no signs of any galvanic pitting.
Thanks for your help!
