Multi purpose grease on prop hub??
If you are talking about a shaft with splines I would suggest the blue grease in a small tube that Volvo sell
If a taper then any grease would be pushed out when the prop is fitted
Sorry, probably should have mentioned it's a stern drive prop I am fitting so the thrust washer is a taper fit but the prop itself is on a spline..
