Rum Run
My 22' boat was designed to have an outboard in a well but has a diesel inboard retrofitted. The 30l fuel tank was fixed in a cockpit side locker with the bottom roughly level with the cockpit floor and somewhat above the level of the engines' lift pump. It all works fine, but with a full tank it is difficult to trim out a bit of a list and the weight is quite high up.
I am considering moving the tank from the locker to a spot on the centre line below the cockpit floor which already has good access via a hatch. The tank is stainless, with all the connections in the top. The new position will be close to the water lock and wet exhaust pipe. I would also like to put the filler cap under the hatch as the current position on the coaming would be need a long filler pipe. The breather could stay as-is. The maximum lift from the tank bottom to the engine fuel pump would be around 15".
So the question is: are there any pit falls, gotchas or points to beware of in making the move?
Thanks in advance
Rum Run
Thanks in advance
Rum Run
