rwoofer
Having had to fix a leaking water pump I finally figured out that my two water tanks (same size, one port, one starboard) are connected by the one pipe that the water pump takes a feed off. Since I only have one filling hole in the deck, so I presume the tanks must balance through this one pipe.
Now the question: If both my tanks are half full and I start healing to the wind, does all the water move down to the leeward tank? If it does that means I would the equivalent of 4 or 5 people sitting on the wrong side of the boat!!
Got me thinking...If I was to put a valve on the pipe I could use the water tanks as movable ballast ie. just before the tack, let all the water rush down, close the valve and then tack. That way I would have the 4 or 5 gorillas on the windward rail making me go faster.
Anything wrong with the theory?
Does water somehow magically stay where it is when healing, therefore scuppering the whole idea?
RB
RB
