skyflyer
The mousing line broke so I now have to try and thread an 8mm forestay through a Schaeffer furling foil. For those that are unfamiliar with the construction, it is a series of hollow tubes (approx 25mm internal diameter) connected by riveting to a similar outside diameter cylinder about 100mm long, with about a 9mm hole through it.
So, as you push the cable through the first hole it is free to whip about inside the furling tube until it hits the end of the next connecting rod section - unless you are extraordinarily lucky and hit the 9mm hole dead centre! There are six connection sections so you need to be very lucky, frequently!
Actually its not quite as bad as I stated above as the internal section isn't circular due to the grooves for the headsail bolt rope. So in fact the bottom of the 9mm hole is level with the bottom of the furler tube, but it still needs to be central laterally - this is the exploded diagram http://www.schaefermarine.com/wp-content/uploads/2015/01/SchaeferFurlers2100.pdf
So - any bright ideas how to thread the forestay?
Thanks in anticipation - someone must have had this problem before ( I hope!)
