thesaintlyone
So ordered 5m extension cables with Mc4 connections in 4mm which appeared to be the size supplied with the Solar Panel Kits.
Plan is to Mount the Semi Flex Solar panel on the Hatch Garage and feed the cables down to the solar controller mounted above battery compartment in the port rear quater berth. Which will be more storage than sleeping area.
I am looking for ways to mount the solar panel via the six holes on the outside but not sure what to use. Have it in mind to use some form of hook screw
What do you guys think.
Regards
Regards
