Franknstein2019
New Member
Hi All
I'm trying to mount my 1998 Mercury 90HP to a fibreglass hull (circa 1985) - its an 18ft planing hull made by Shetland in England.
My Mercury seems to have the standard mounting hole pattern.
I've just checked the holes in the transom, and the two lower ones are good at 9 7/8" apart.
However the top two holes are at 12 3/5" apart instead of the standard 12 7/8" !
That means I cant mount it without filling and re-drilling I assume.
I'm trying to establish why this is. They are the original holes, and theres no evidence of multiple drill holes so I assume these were drilled from new and it had a motor on it for its life before I got it (without motor).
Is there an older style motor with a 12 3/5" mounting hole distance on the top two holes?
I dont know what motor it had on it before, but if its like most of these hulls in the UK, they're generally fitted with 30HP or thereabouts.
So my next question would be how should I go about filling these holes so I can re-drill them to the correct location? I'll probably re-check the locations of all four holes using drafting techniques on the transom.
My concern is that the difference between the old and new holes are close enough that'd I'd be re-drilling through half of the 'old-hole repair'.
:disgust:
:disgust:
