Motorboat rescued by RNLI
Steruth1
1 Sep 2013
Southampton
It was moored up yesterday in the harbour and the chap was washing it down so all looked ok, looked like a fairly new predator so no idea how the fire suppression system activated . It was pretty rolly out so glad they were ok.
oldgit
6 Nov 2001
Medway
Without being too judgemental and looking at where they were and who was onboard .. The skipper ever heard of weather forecasts ?.................
" three children " who were suffering seasickness.
Portofino
10 Apr 2011
Boat- Western Med
Maybe a kid sat with dad on the helm kicked the toggle ? ā€¦.you know bumpy sea and the mother was moaning stressing dad out . It would be difficult for none helming to stand up so the other 4 wound seated somewhere.
Never been a great fan of those seafire systems wherby some electrotwackery in theory could stop the motors .
When I had my sun squeaker the pin was often left in the canister and yes the toggle switch was knee height waiting to be booted or bashed into .If it was at the top of the dash say adjacent to the compass then it canā€™t get accidentally bashed in a big sea .
Much prefer a manual system with zero extra electrotwackery interlocked into the engines in a un bash able dash location .
petem
Cotswolds / Altea
www.fairlineownersclub.com
The switch on the helm will only ever override the system once the extinguisher has been fired. It will never stop the engines.
To active the engine shut down you need a closed circuit on one of the extinguisher sensors. Pulling the wire out will allow the engines to re-start.
Or locating the SeaFire control box and disconnecting the wires to the engine stop solenoid solenoids would also allow the engines to be re-started.
The RNLI would have been better off calling SeaStart or a boat mechanic to get the thing running again (easy for me to say I know).
Bouba
6 Sep 2016
SoF
Interestingly, we are all arguing over what to doā€¦the skipper would probably be equally confused with the added concern of a frightened family and a violently pitching craft
Scubadoo
Hampshire / Solent
If all it takes is throwing a switch to get the engines going again, maybe the the skipper should be more firmilar with their boat systems before going out in conditions as described by the RNLI. However, I appreciate it might not be as simple as that and maybe a system fault had prevented the engines from restarting.
volvopaul
1 Apr 2007
midlands
hotmail.co.uk
It will stop the engines if the plug comes out the bottle valve
madabouttheboat
20 Jan 2005
UK, but for Covid it's England
I wonder if ā€œtriggeredā€ means the extinguisher actually activated. In that case the contents would be drawn into the engine and severely block it
Modern gas one may stop the engine but should not block anything. Dry powder might block the air filter, but a change on the hoof should get it going again.
PowerYachtBlog
21 May 2007
Malta - Med Sea
www.poweryachtblog.com
A modern boat will be fitted with a clean extinguishant. I know this from having an engine room extinguisher fully discharge a few feet away from me.
Yes, but you can change it on any boat. I suggest to everyone to switch to FM200 in there engine room, resolves a big issue, and nowadays the price is fairly competitive.
I just switched mine this year. I would be surprised if a quite new Predator 50 2018-20 would not have an FM-200 system.
oldgit
6 Nov 2001
Medway
OG firmly believes that you might work out how to switch on and off most of the fairly important bits on your boat after about a year and begin to discover , more by accident than design , then how most of the rest works...........shortly before you sell it.
Took me ages to discover that two weeny little switches at the helm muted the engine alarms.
Bouba
6 Sep 2016
SoF
When something happens on a boat you need your dispassionate logical head on....unfortunately when faced with a serious situation we go into panic mode....something that might have easily occurred to the skipper while anchored in a quiet bay may be the last thing on his mind. So I think we need to be less judgmental...we were told in the very beginning the cause...he wasnā€™t....and in a modern fifty foot boat there are numerous systems and components....
ylop
10 Oct 2016
Children could be anything from a baby to 17. Sea sickness could be anything from clinging to the gunwales piling your guts up to feeling a bit green. Where they ill before the engine stopped or just when rolling around powerless? Did the anxiety of being ā€œstranded at seaā€ increase the sickness? Did mentioning it help the CG make up their mind on what help to organise? Did including it in the press release help the RNLI seem more like rescue than tow serviceā€¦
I stand corrected but in that case joining the two wires together (in the event that there's an issue with the override switch) will allow the engines to be re-started.
Easy to say sitting on dry land I know.
RNLI crew are well meaning but not necessarily mechanically adept and donā€™t know every boats little quirks. What they should have done to avoid such a long slow tow back was post on here - theyā€™d have been told how to fix a problem that may or may not be the one that was experienced.
Yes and the RNLI crew didnā€™t see the problem either (I know someone who once called them out, expecting a lengthy tow - to be toldā€¦ ā€œsee that red springy cord around your legā€¦ could you plug the other end into the controls!ā€) nor did the CGā€™s (or RNLI shore crew / DLA who are often wise crusty old boaters) - Iā€™ve heard Belfast CG talk through some basic engine checks for someone and get them going.
