Darwining
New Member
Hi,
Me and my partner have a Hurley 2470 with a Morse throttle attached to a Nanni engine-- the kind of single throttle that pulls out to go into neutral, wherein you move it forward to start the engine, and then return the throttle to the centre position and push in (or it "snaps back into place") to engage, then forward engaged to go forward, and move towards aft for reverse.
I anticipate that we, novice boat owners and general idiots, have messed up something recently (explanation forthcoming) as now the throttle is not only stiff in moving forward and back (in neutral, although I assume also engaged but we haven't moved since the incident) but also almost immovably stuck in the push-in/pull-out engaged/neutral positions. I've done my share of googling and looking at cables, and feeding oil through them, etc, and I've looked into the gear mechanism, and attacked it with marine grease and tried to work some into the cables. However I can't find any info on the in/out part of the throttle mechanism, and while it's stiff laterally it's almost uselessly seized in that in/out position.
The incident mentioned above is that while in the marina we tried to "repark" the boat form fore-in to aft-in, but the proximity of expensive boats and some general newbie-panicking resulted in one of us gunning the engine from forward into reverse quite quickly, a few times, something that I have later discovered is a "do not ever do this or terrible things will happen". Before that the throttle was a little stiff but usable, now it refuses to cooperate.
My hands are covered in marine grease and I'm pretty frustrated, so any light to shed would be amazing. Or I guess just call a professional and beg forgiveness for whatever we've done...
Thanks all.
Thanks all.
